Is my 2.4L engine shot ?
equinoxwoman
I have a 2013 with a 2.4L ecotec engine, automatic transmission, with only 60k miles. The past couple days it has started sounding like a diesel all the time idling or driving, so my bf changed the oil and did a compression check. He said the compression was ~ 220 psi each cylinder so seemed good, but noticed fine pieces of metal on the oil filter and bottom of the oil pan when changing the oil. There are no codes and seems to drive ok but sounds bad.
TARDIS B
You may be covered by a recall of the timing chain going bad. It was a class action lawsuit.
Write your reply...
