Hyper flashing stock LED rear turn signal
Elda135
Hello everyone, I have a 2019 Equinox Premier 2.0 with the LED taillights/headlights and recently I was at home depot and someone backed into my right rear taillight/turn signal and it cracked. It was raining and the taillight got messed up and started hyper flashing when turning on turn signal, so I went to eBay and I bought a used OEM LED Taillight replacement which looks in pretty good condition to replace the broken one. Once I had installed it was working perfectly and got on the road and the taillight has hyper flashing as if a bulb was out but it isn’t and the led seems to be in excellent condition it just hyper flashes. I went to check on the fuses and the relays but it everything seems to be in good condition. Any guesses as to what it may be? I was guessing since it’s an led does it have to be programmed by the dealer or what could be the issue?
Big Papi
"I went to eBay and I bought a used" could be the crux of the issue. Testing will confirm. Start with pin fitment.
Elda135
I already went through the pins and everything seems in perfect condition it was a oem taillight.
