2014 Equinox, 2.4 FWD. I had replaced the: thermostat, radiator, coolant (obviously), purged the air & the climate control module behind the radio/climate controls, the blower motor resistor, and the blend door actuator. SOMEHOW, I'm still unable to get heat inside the cabin & at running temperature the heater core hoses are sitting pretty hot as I can't grab onto them for more than a second, they're hot to the touch. I'm not leaking coolant & using DEXCOOL only. Its 22 degrees in Detroit currently & am struggling to find the solution to this, can anyone either relate or point me towards a potential solution? (I've got the manual HVAC controls/system not the automatic)
