Front End Dilema
Teezbeez
Hi. I've got a bit of a problem with my 08 Equinox LTZ. I hit a concrete pole. Not head on or backing up. I was turning and turned into it because my sandal came unbuckled and got wrapped around my stupid foot. You had to be there. Anyway, the left front side starting at the front of the wheel well and went all the way down the side. I have chrome pipe running boards. The left one got bent back. The left front tire got "pinched" and went flat. Took off the left front tire. The shock was clearly not straight. Changed it. The tire still sits back too far to the right. It rubs the inside of the wheel well. Can somebody give me a clue regarding what else I could have bent to make the tire rub? I know no matter what its not gonna be good news. Thanks so much.
Easy. Have a garage look at.
Bent strut? Bent control arm?
Maybe bent tie rod too.
Parts are cheap. Labor is high.
