Ok, i have a 2012 Equinox has the following issues.
Check engine light
Service stabilitrack
Reduced engine power. ( failsafe mode)
Ran the ODT scan tool and pulled codes
P0016 crank shaft pos sensor
P0089 fuel rail pres. Sensor
P0228 throttle/accellorator pos sensor
P0191 fuel pressure performance
When all the trouble started the engine would just want to die as you came to a stop in traffic and ran rough there after.
The problem would reset if you turned the key to off and then back on.
I replaced the crankshaft pos sensor
And the accelorator pedal
Cleared faults
Ran a fuel pressure check but the car would not run long enough for sufficient diagnostics.
I also cleaned the throttle body and inspected all electrical connections on the front of the car related to the fuel system.
The car does not even start not.
I suspect a fuel pump
I am at a loss, money is key here because we really dont have any.
Any help would be greatly apretiated
Check engine light
Cleared faults
