2025 info for wire and/or replacement TVA, MVA, AIVA, LIN Bus 6
penright
I hope I am in the right sub-section. In most other forums I belong to, the how to more instruction on a subject, but I see a lot of questions here so I am not sure what the correct etiquette is. If I am wrong, maybe an admin can help me move it to the correct one. :) Since the 2025 model is so new there is limited information out there and any answer to my question could be of future help.
TVA - Temperature Valve Actuator (Left/Right)
MVA - Mode Valve Actuator
AIVA - Air Inlet Valve Actuator
Does anyone have access to schematics, parts locations, etc around the TVA, MVA, AIVA, LIN Bus 6?
I will take it to the dealership for the repair but I wanted to know as much as possible before and after I do.
I have codes for all the actuators mentioned in the post, including a LIN Bus 6 code, which suggests this might be the issue. I am curious if they share the same LIN Bus and if any other CM share it.
The actual codes are ...
