2024 equinox battery drain problem
robbie
2024 equinox with 1700 miles. Have to charge battery every time I need to drive it. I reported the problem when I took it in for the 1 year service. All they did was check the battery and said it was OK. I will take it back in next week and I hope they will fix the problem. Anyone with this problem?
Moonwink
SW of St Louis, MO
I wish I had something to offer other than I had a 2009 HHR that developed a parasitic drain on the battery. I was never able to pin it down. I kept it on a "float charger" (they never overcharge the battery) so it was always ready to use. It would take about 5 days for the battery to go flat - no dome lights or click when I'd try to start it. At that point it needed a jump. That's VERY hard on batteries. I fixed it by trading it for my 2015 Malibu. :rolleyes:
How quickly does the battery discharge?
Has the battery been replaced?
If the battery passes a load test, a crank test and a charging test. Need all 3 tests (can do this with a simple $30 digital battery tester). Next thing to look at is a parasitic draw, what circuit the parasitic draw is on and what component is causing it.
RadioHead
If your battery drains in a week that's a tramedous amount of draw going on.
Hopefully you are still under warranty. If so have Chevy fix it. If not you can do some trouble shooting if you understand and are semi mechanically and electrically apt. It's not real difficult but takes a bit of time troubleshooting.
Search Parasitic battery draw or drain online. Watch a couple videos. You'll need a Digital Multi Meter (DMM) that has the option for amperage readings. You'll need to place the meter in circuit with the battery connection/wiring and probably have someone else read it for you, as you pull each fuse one by one to see if the current draw suddenly drops to less of a draw. Each car has a small amount of parasitic drain for all the electrical components and computer. As more technology comes online the higher the drain. You'll also need to have all the doors etc, shut when doing this. If a light comes on or a sensor is reading this, that's another area draining.
Once you find the fuse that is the culprit, then you must troubleshoot further to see which component within that fuse circuit is draining the battery. There could be a few items on that fuse circuit, or just one. It could also be a short somewhere in the wiring harness, that would be a little tougher to locate but possible.
Good luck, let us know how it goes.
Moonwink
SW of St Louis, MO
More answers here:
Dead battery​
Hope it will shed some light on finding an answer.
