2020 Equinox Suspension Noises
adamastone78
Arizona
I have a 2020 Equinox that I love. I bought it used in 2023 and have had a lot of suspension issues with it. WIthin 3 months, Chevy had to replace upper and lower control arms and bushings. They also had to replace some stuff in the back. Now, 16 months later, the car was making noises when going over bumps and speedbumps. Took the car in and they said stabilizer bar. They replaced that with the bushings. Car was still making noises. Took it back. They said it was struts and strut mounts. They replaced those and the car is STILL making noises. This is a Chevy dealer and they can't figure it out. They have now sent in a ticket to GM Engineering to get help. Anyone have any ideas?
Big Papi
What noises? A clunk, a thud, squeak, scrape, grind, howl, moan, whistle, boing, clang, rattle, buzz, screech, boom, or something else?
Krash32
Without any additional information, I can tell you just from personal experience with my 2018 that I had a defined clicking/clunking sound especially at low speeds over bumps and uneven pavement. I fixed it myself for free; it was the bolts on the stabilizer bar links on the front driver side were slightly loose. The passenger side were loose as well but not quite enough for movement. I tightened them up with a torque wrench and haven’t had an issue since. Worth a check, it’s free and easy to DIY. This was around 100K miles.
I could replicate the sound/feel by opening the driver side door and pushing up/down on the door jamb to rock the car side to side somewhat aggressively; I tried this from all four sides of the car and could hear it coming from that area the clearest. Again we don’t have much info to go on, but given you said speed bumps and same gen. Equinox, why not check it out.
adamastone78
Arizona
I describe it as a crunching/grinding noise. I especially notice it when going over speedbumps at a low speed. **UPDATE** went to pick it up from the dealer Friday. They replaced driver side lower control arm. Drove the car over a speedbump at the dealer and brought it right back to them.
adamastone78
Arizona
They just replaced the stabilizer bar and all of that... Still made the noise after. Then they replaced the struts and strut mounts claiming that would fix it. Still does it. Now they replaced the drivers side lower control arm and it still does it. Today they're doing the passenger side control arm. They're literally throwing parts at it. Claim they even brought in a GM engineer.
azjeff
Hope this is all under some kind of warranty. Just bought our 2020 in February and with a January 2020 build date all warranties up.
Good luck.
adamastone78
Arizona
Good luck.
MOST has been under warranty. I bought their warranty from AutoNation when I bought the vehicle. It's just odd (not really) that they are really struggling to find the cause. I LOVE the vehicle, but maybe it's time to take it elsewhere to be looked at...
Krash32
To be fair they don’t have to actually remove the sway bar links in the front to replace the stabilizer bar; if they removed the bar they only loosened the lower bolt that actually connects to the bar and didn’t touch the upper part that bolts to the frame, which is where mine became loose. The sway bar links are made of plastic so they could literally just be broken as well. That was just my experience though. I hope you can get it resolved soon.
adamastone78
Arizona
Thank you for that. I have another phone call today with the service manager and will mention that to him. I appreciate your insight!
adamastone78
Arizona
UPDATE****
They have now replaced the control arms... The noise is still there. Here's an EXACT quote from my service advisor... "Spoke with the tech and swapped out the control arm and noise is still there so he said hes gonna do some process and elimination and start removing parts and drive it until the sound is gone and replace the part".
Are we serious? Is this even normal?
UPDATE****
It might be a rough road test without suspension parts installed. doesn't sound normal to me- unless he is talking about sway bar links, that's about the only thing I could think of that could be removed and still have a somewhat safe road test.
adamastone78
Arizona
I mentioned to the service advisor about the sway bar links (being loose and/or broken) and he got extremely defensive saying he's "absolutely sure" his mechanic would have checked that :ROFLMAO:.
I appreciate the suggestion.
GaryM
The links for the sway bars are a common issue. I replaced two on mine.
I’ve had 15 equinoxes. I fix them. 88% have front end noise. I’ve done struts and sway bar links. Which help. I’ve done control arms. Which helps. I have a noise when I wiggle steering wheel. Been told it’s intermediate shaft play. I changed steering assist motor on current rig. Made zero difference. Loose rack bushings?
Write your reply...
