2019 quinox awd grease points
americanchadazz
Is there any grease spots on a 2019 equinox? I know stock parts don't have grease certs but for instance balljoints and tie rods I use a grease needle. Is there any other parts that I can grease like that, mainly wondering about the drives shaft?
There really isn't anything to stab a grease needle into on the AWD system. There is one carrier bearing mid way that you could maybe inject grease into. No u joints. More of a CV joint coupling. The way the prop shaft jogs to the driver's side is normal on the 2018+. It looks really odd the first time you notice it. It looks like things are misaligned.
