2019 FWD LS 1.5L Transmission Slipping In First Gear
JA Freud
Had a P0171D code after transmission was shifting erratic. Changed the fluid, looked pretty good, but only drained about 3 1/2 quarts. Refilled till it came out the observation plug, started the engine and shifted through the gears twice, topped it off. Now slipping a lot in first gear after warmed up. Any thoughts? Thanks.
The engine needs to be idling with the transmission in park, with the ATF up to temp and the vehicle parked on a level surface to check level at the level check plug.
Fluid will pour out of the level check plug if you do the procedure wrong. Engine off, etc.
Done correctly, fluid should just dribble out when the level is correct.
SheeB
I had to use a scan tool to read the transmission temperature (I recall 165F) and then top up fluid till it dribbles out of the inspection hole on the side of the transmission with engine running (be safe).
Old thread here and the OP is probably long gone. Just to add to what @SheeB said with the book way of doing it, you should get closer to 4.5qts of fluid per drain. I've probably done 5 drain/fills on my 2021 1.5T 6AT. 4.5qts every time. I very much doubt the 1qt situation is effecting the OP, but I thought it was worth mentioning.
