2019 chevy equinox lt 1.5 awd side detection module..dash lights up. Locks on off no security light..battery and power system ok
Hipshooter7
My 19 equinox had a message to service side detection system..lights on dash..tpms restraint..track control etc plus random service messages..locks on off..goes dead..1 click faint light on then off. Brake pedal hard.gauges go flat then come on.happened all of a sudden..seems to run ok when it runs..I have no clue..car is cleaned every day.
Hipshooter7
Also no check engine light
if the brake pedal is hard, this could mean a vacuum pump failure. If you continue to drive it, plastic pieces could get inside your engine and cause severe damage. Not sure if the other lights could be related, but either replace the pump and be sure to get all the plastic peices out, or have it towed to get it done.
Multiple systems failures could also indicate a weak battery - have it load tested.
Hipshooter7
Keeps showing side detection system service..battery and charging system are good..tested..all the other lights are very intermittent now but side detection happens on start up then dismiss it and goes away until started again
Could be one of the sensors in front or rear bumper, or a control module. If you don't have a scan tool or don't care to check connectors to the sensors, a trip to your mechanic is the best route.
