Plan is to get a new rebuilt transmission, but first I need to sort out the cooler line issue, 05 was a bastard child, I trying to find out if I can get some adapters to use 06 lines, they used a quick connect fitting, or patch up these with some steel line and compression fittings. I bought this truck from a friend, he had no clue about the lines, it was running and driving with no leaks, I took the lines off and drained the fluid. Used Aisin T-IV fluid, I assure you the fluid was burnt black to a crisp, can't see how much fluid got through those cooler lines.What is plan?
Used lines from junkyard?
Used trans?
Ya sure you didn’t lose fluid thru leak?
Did you use t-4a Toyo fluid?
