1st Gen : 2005-2009 Chevy Equinox
06 LT Will only start in neutral
<blockquote data-quote="rlshepard" data-source="post: 13804" data-attributes="member: 2346"><p>Okay, I need some help. So I went to the salvage yard and pulled a neutral safety switch. and the problem was fixed! until now. its back the car will not start in crank in any gear no click no nada. Battery and Started are both new. </p><p></p><p>I've read some snippets that suggest this could be a key issue? do these keys have a chip? it doesn't look like it does....</p><p></p><p>Is there a common failure that causes this no crank condition? any test that can tell me if its the PCM or if my salvage neutral switch has failed me?</p></blockquote><p></p>
[QUOTE="rlshepard, post: 13804, member: 2346"] Okay, I need some help. So I went to the salvage yard and pulled a neutral safety switch. and the problem was fixed! until now. its back the car will not start in crank in any gear no click no nada. Battery and Started are both new. I've read some snippets that suggest this could be a key issue? do these keys have a chip? it doesn't look like it does.... Is there a common failure that causes this no crank condition? any test that can tell me if its the PCM or if my salvage neutral switch has failed me? [/QUOTE]
